Howdy,
I have just recently completed a project using a picaxe microcontroller after advise from helpful folks on this forum.
It was pretty straight forward and easy using the starter pack which I purchased. However, that being said, I want to now build another board for it as I have purchased multiple IC's. I went down to the local components store and got my self a small proto board to work with, but I have no idea how you're meant to lay the circuit out on these things, do I just run wires, is there something else I need to etch railings or something?
What's the cheapest easiest way of doing it? I tried using wires and tried to make connections between the two copper edged holes with big blobs of solder, but this didn't seem to work.
I dunno, maybe I fried the particular IC I'm using, all I'm going by is it didn't connect when I tried to download a program to it from the pc. Help is appreciated.
I guess the short version of what Im asking, are there any resources that explain prototyping without a pre printed circuit board?
