I am interested in a simple non-PWM fan-temperature-controller for a server that I am modifying (the existing PWM fans scream, however I can not simply turn them down with a resistor as they must also respond to changes in server load... I am replacing 14 40mm fans with 4 80mm non-PWM fans).
I found this very simple circuit http://www.heatsink-guide.com/tempcontrol.htm
But I would like a version of it that adjusts the 12V wire rather than the ground wire so it can be used with the fan's tachometer and wondered if anyone here would be so kind as to design the circuit for me. The page actually mentions a modification of the circuit that could be used with the fan's tach using a P-Channel MOSFET instead of an N-Channel MOSFET, but I wouldn't know which modifications to make.
I am interested in other simple fan-temperature control circuits if someone knows a good one. The three component circuit above is attractive as it is so simple... I find other circuits on google that may work but are considerably more complex.
Regards, James
Regards, James
