non-inverting summing amp
fran1942
Joined Jul 26, 2010
58
Hello, my tutor has asked me to sketch a non-inverting summing amp with three inputs.
I understand all the other common amp configurations, but I am unsure how to sketch this one.
Can someone please show me a basic example with some figures so I can clearly see how the individual gains are calculated with three inputs ?
Thanks kindly for any help.
(I have searched the web, but most examples just have formulas rather than actual figures)
hgmjr
Joined Jan 28, 2005
9,027
Are you allowed to use two opamps? If so, then add an inverting unity gain opamp to the output of your inverting summing amplifier.
hgmjr
hgmjr
Joined Jan 28, 2005
9,027
thanks, great advice,
Would this attached sketch work.
I need gains of 4, 10 and 15.
Thanks kindly
Sorry that will not do the trick. You have used a non-inverting unity gain buffer. What you need is an inverting unity gain amplifier.
hgmjr
Wendy
Joined Mar 24, 2008
23,421
It is a unity gain inverter circuit. Which is why converts the first inverting circuit into a non inverting circuit per your requirements.
The exact resistors values aren't important, they need to be the same values for unity gain.
