Non inverting audio amplifier
ericgibbs
Joined Jan 29, 2010
21,571
hi Paul,
Do you have a question about that amplifier circuit?
It is common practice to apply a DC offset to a OPA when using a Single power supply, what are the power supplies to this circuit?
E
Paul Bober
Joined May 11, 2024
86
hi Paul,
E
Is it okay to use my voltage divider, as part of my gain determining resistance ? Is it okay to use my voltage
hi Paul,
E
1 Is it okay to use my voltage divider as part of my gain determining resistance ? 2 Is it okay to use my voltage divider as ground potential, for my gain loop ?
Paul Bober
Joined May 11, 2024
86
In case there is any noise on the d.c. output of the a.c. to d.c. power supply, the noise is applied to both inputs. If you have equal amounts of noise at both inputs, there is no potential difference to be amplified.
Bordodynov
Joined May 20, 2015
3,431
I did a parametric analysis using .Step param a 0.65 0.8 50m. The program made 4 calculations with different input signal amplitudes. The signal varied from 0.65V to 0.8V with a step of 50mV. I have shown that with equal resistors of 100K, there is an asymmetric limitation. And when using 100K and 120K resistors, the limitation is symmetrical.
This allows you to get a larger dynamic range of the input signal without limiting the output of the amplifier.
This is what Paul Bober wanted.
Paul Bober
Joined May 11, 2024
86
I only need the preamp to boost the guitar signal up to -10db, to feed into the RCA line level inputs found on home stereo equipment.
