Non Inductive Resistor.
R!f@@
Joined Apr 2, 2009
10,004
My circuit requires 0.02Ω non inductive resistor.
So after going through my junk I found two 0.01Ω white 5W power R's. Those flat rectangular vertical ones
I dunno if those are non inductive types.
I hooked it up to the inductance meter and it shows 0.00μH.
Is it safe to assume that these are none-inductive?
Are they also refereed as Power Oxide types?
I hooked up a 1Ω 0.25Wmetal film one and it shows 0.12μH.
Are metal film Resistors Inductive ?
dl324
Joined Mar 30, 2015
18,326
Sounds like you're describing a cermet power resistor. They're non-inductive.
Yes. The metal film is wrapped (actually most likely sputtered) spirally around a ceramic core.
