Nodal Analysis
BobTPH
Joined Jun 5, 2013
11,647
1. Identify nodes and write the KCL equations for them.
2. Identify loops and write the KVL equations for them.
3. Solve the equations.
WBahn
Joined Mar 31, 2012
33,187
Can someone help me with this question? How should i solve this?
The question is value of V0
You need to show YOUR best attempt to get as far as you can. We can then help you identify where you have gone wrong or give suggestions to get you to the next step.
WBahn
Joined Mar 31, 2012
33,187
The thread title indicates that they are expected to use a specific technique, namely node voltage analysis.
BobTPH
Joined Jun 5, 2013
11,647
You are right. Revised advice.
1. Identify all essential nodes.
2. Pick one as the reference (ground)
3. Assign voltages V1, V2… to the other essential nodes
4. Write an equation for the current out of each of these nodes.
5. Solve the equations for V1,V2…
6. Compute V0 from the resulting voltages.
