Solve By Nodal Analysis
yousha4835
Joined Jan 17, 2025
well i tried but i am nowhere near the solution.I'm Sorry
ik kvl and kcl i tried both but its not giving the right answer i tried with mesh analysis and it was solved right away
but not with nodal analysis
BobTPH
Joined Jun 5, 2013
11,661
Show us the equations you set up.
I am studying this myself right now, so I did the problem using KCL and KVL and got the right answer once I fixed my signs.
I see two unknown currents and two nodes, so one KCL equation. I see one loop where the voltages can be determined, so that gives us a second equation.
Two equations, two unknowns.
Show us what you came up with.
WBahn
Joined Mar 31, 2012
33,257
So show us your work when you tried to use nodal analysis. We can't figure out where you went wrong when you won't show us where you went at all.
