Nodal analysis with no resistor between node
eutos
Joined Mar 9, 2021
I can't seem to get the answer. referring notes and tutorial makes me even more confuse on how to do the calculation (since i prefer to get the example and solution based on attached question). i appreciate the help thanks. (just saying in advance)nodal.PNG
MrAl
Joined Jun 17, 2014
13,819
I can't seem to get the answer. referring notes and tutorial makes me even more confuse on how to do the calculation (since i prefer to get the example and solution based on attached question). i appreciate the help thanks. (just saying in advance)View attachment 232333
You also might want to mention why you are stating that there is no resistor between nodes, why you think you need that to solve this or really any circuit problem. That will show what theoretical concept you need to know that you might be missing in order to solve this.
BobTPH
Joined Jun 5, 2013
11,662
I don’t understand rhe diagram. Are both the yellow circle and the square supposed to be current sources, or is the square a Voltage source? I think it cannot be a voltage because then you would have two conflicting voltages.
Bob
MrAl
Joined Jun 17, 2014
13,819
Bob
They are both current sources, the one on the left is constant the one on the right is a dependent current source.
