No Current, No Voltage?
Hexspa
Joined Jul 3, 2023
7
Hi, first post. This is a question I put under the Voltage, Current, and Resistance Worksheet ( https://www.allaboutcircuits.com/worksheets/voltage-current-and-resistance/ ) but I think this forum might answer faster:
I can understand that voltage is potential energy to move an electron between two points and that something like a battery stores this potential independently of current flow. However, if Ohm’s Law states that V=IR and anything multiplied by zero is zero then V=0x has to be V=0. No current, no voltage. How to reconcile this seeming paradox?
WBahn
Joined Mar 31, 2012
33,109
No paradox -- Ohm's Law applies to resistors and a battery is not a resistor.
Ohm's Law says that the voltage ACROSS a resistor is equal to the product of the resistance and the current THROUGH the resistor.
So for an unconnected battery, the resistance that the 12 V is across is infinite and there is zero current.
I = V/R = 12 V / oo Ω = 0 A
For
V = I·R
You have (0 A)( oo Ω) which, mathematically, is what is known as an "indeterminant form", meaning that it could be anything. In this case, it's 12 V.
https://forum.allaboutcircuits.com/threads/ohms-law-when-r-0.84677/post-606530
Hexspa
Joined Jul 3, 2023
7
For
V = I·R
I see my mistake which is I didn’t account for the resistance value. Even if I had, I’ve never heard of indeterminate forms. Nsaspook’s link took me into limit theory which, while I’ve heard of such concepts from audio dynamic range compressors, I’m a long way from grasping the math. Thanks for your help.
