OK, I got some numbers today. The voltage tends to drift downward slowly but I don't understand exactly why at this point. I took the reading when it looked like the voltage drop had slowed significantly. I switched between resistors as quickly as possible to try and get similar conditions throughout the range of resistor measurements.
infinite = 0.88 v
10 M = 0.88 v
1 M = 0.88 v
100 K = 0.88 v
10 K = 0.62 v
1 K = 0.20 v
At the end of the last reading with the 1K resistor I went back to infinity to see if I had the same conditions. My reading started out low and drifted UP to 0.84 v. Also, I did a kind of trial run in which the 10K and 1K readings were within 5 to 10 percent of the numbers above.
Hopefully that gives you something to work your equations with. I can redo the test anytime if you think it necessary.
Thanks.
infinite = 0.88 v
10 M = 0.88 v
1 M = 0.88 v
100 K = 0.88 v
10 K = 0.62 v
1 K = 0.20 v
Thanks.
