KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
The "production" method is to use an oven. The home brew method converts a "toaster oven" and uses a profile controller. This http://www.zallus.com/msp430-reflow-oven-kit/ is probably the coolest that I have found.So I have to buy a hot air gun in order to do this properly?
Note, how the guy used standoffs to raise the PCB off the ground on the bench. If he mounts it, he might make the posts shorter and put them on the front.
The PCB manufacturer can supply stencils in either Kapton or stainless steel.
The board that I made, I did without hot air or solder paste. My first CPU chip that I soldered I didn't use hot air either, but 63/37 solder made all the difference in the world. I just tacked the corners and used an "upside down" technique which you solder the pins when the component was upside down. You just drag solder across all of the pins. 60/40 solder will easily bridge the pins.
Look at the AD8231 outline. http://www.analog.com/media/en/technical-documentation/data-sheets/AD8231.pdf#page=24 That part is 4 mm square or about 0.160". If you like fractions, then about 5/32 of an inch square. Pretty darn tiny. Note that the pads are mostly under the IC. There's no way to solder the "exposed pad" with an iron, but the pad does not need to be connected for this part. So, for proto-typing have proto-advantage do it. I think the other parts are 3 mm square.
1206 sized resistors that I chose are physically big, so you can handle them. Those parts (resistors typically) can be selected with a smaller package.
Page 32 here http://www.henkel-adhesives.com/com...ronics_Assy_Brochure_finalLR_Distribution.pdf discusses some adhesives that can assist assembly. it's not strictly required. But if you had a heavy part mounted on both sides of the board, then it's useful. It's an extra step for assemblers. Superglue works in a pinch.
I have the BK6000 (discontinued) version of this (BK8000 https://www.circuitspecialists.com/...8000-all-in-one-soldering-rework-station.html it's definitely a low-cost product. I had/have a few issues:
1. You can't use solder/de-solder at the same time.
2. The solder iron heater like to fall out. (fix: push it in once in a while)
3. The de-solder gun sticks in spring holder. Fixed with a $30.00 reamer. (borrowing is probably OK)
4. Not having the pin-out makes it hard to trouble-shoot (available elsewhere on-line)
5. You need a thermal compound on the gun system.
Metcal is often considered the cream of the crop because it uses an induction heater. Virtually no warm up or cool down time.
A self-contained de-solder tool is probably better, but they cost more than this.
At this stage, let proto-advantage do the IC soldering. The dipping this isn't going to work.
I have a story to tell. I did an automation project for a guy that built models from brass that was cut by etching. His assembly technique was to "drip" the solder. I told him about "resistance soldering" which passes a current through the parts and he switched to that method. It's really great for soldering pins on connectors.
