Newbie 10K Pot testing MCP3008
bibble235
Joined May 29, 2018
57
I have been trying to test the mcp3008 using a 10k pot on Raspberry Pi using the guide
https://cdn-learn.adafruit.com/down...olling-audio-volume-with-the-raspberry-pi.pdf
Unfortunately the only Pot I had was this
https://www.jaycar.co.nz/10k-ohm-li...1e33265dded073f654fea3dfa001e4&sort=relevance
When I run the program and turn the device I see
0.0004885197850512668
from gpiozero import MCP3008
import time
pot = MCP3008(0)
print(pot.value)
while True:
time.sleep(1)
print(pot.value)
I am wondering if the pins are too short for a breadboard?
Thanks all
Dave Lowther
Joined Sep 8, 2016
224
They do look a bit short.
You could solder some short wires to the legs. I use the inner from jumper wires when I need to do this.
If you have a multimeter you could plug the pot with existing legs into a spare area of the breadboard and see if you can measure the resistance correctly from other spare holes on the same rows.
Presumably if the pot legs aren't connected you would get the same print out regardless of whether the pot is plugged into the bread board or not.
