New Motor?
alfacliff
Joined Dec 13, 2013
2,458
so they are going to higher frequency ac motors? not a very new idea. we have motors here that put out 35 hp you can carry in one hand. just more poles and higher frequency.
BR-549
Joined Sep 22, 2013
4,928
They didn't give that many tech details.
I believe the main idea was the power/weight.
I think also they wanted to keep power/RPM slow for direct propeller and vehicle use.
Glenn Holland
Joined Dec 26, 2014
703
I believe the world's record for power to size is about 2500 Hp in less than 1/2 cubic foot.
It must have very high RPM and low torque and may have used super cooling in liquid nitrogen.
alfacliff
Joined Dec 13, 2013
2,458
we have motors here that are rated at 35 hp, that are easy to carry around. they run on 3 phase3 ac at up to 30,000 hz. also some motors I can carry in one hand rated at 10 hp. higher frequency motors are lighter in wate than lower frequency motors. thats why they use 400 hz on airplanes.
strantor
Joined Oct 3, 2010
6,875
I have spoken with Ed Dempsey of 400Hz engineering about building us an uncommonly tiny 200HP high frequency/high pole-count/low speed(<2000RPM)/high torque motor. He said that when increasing poles there comes a point where you start losing too much power. He said that above 10 poles, if the point is to cram the most power into the smallest space, it no longer makes any sense to continue increasing poles. Going that direction leads to a larger, heavier, more inefficient motor; better results can be achieved with a lower pole higher speed motor with a reducer gearbox (and fit in a smaller space, including the gearbox).
So maybe you're right and they are using a high-pole-count high frequency motor, and Siemens has found a way around the inefficiency issue. Maybe with permanent magnets? But I suspect it may be a different approach to achieve those results.
alfacliff
Joined Dec 13, 2013
2,458
or a low pole count motor. a two p0ole 60 hz motor is rated at 3600 rpm (minus slip) and a 4 pole motor on 60 hz is rated 1800 rwpm (minus slip) why would you need more poles for higher rpm? using a good ferite mix for the poles would allow much higher frequency drive and rpm. the 35,000 rpm three phase spindle motor rated at 35 hp isnt very heavy, but it does require lisquid cooling, being inside the spindle assy. they use a Grasby - volksmann vfd to drive it, as part of a Henri Line milling center.
30,717
The popular Chinese 3ph induction motor water cooled high rpm spindles reach around 24krpm, (400Hz VFD) but are limited to around 8000rpm min, due to their very low inductive reactance at any lower frequency.
AC PM 3 ph servo's usually max out at 8 poles, the high pole count enables smoother control at lower rpm but the higher frequency required to obtain high rpm restricts them to around 6000rpm.
alfacliff
Joined Dec 13, 2013
2,458
The one we use can go real slow, even position. the drive goes much higher than 400 hz. even uses oil mist lube for the ceramic bearings.
strantor
Joined Oct 3, 2010
6,875
Not sure who you are addressing there; if it's me, I wasn't implying that you need more poles for higher RPM. I was talking about increasing frequency to reduce motor size, and in order to increase frequency while keeping RPM in a directly-usable (not requiring a reducing gearbox) range (<250oRPM per the atricle ) would require additional pole pairs.
