panic mode
- Joined Oct 10, 2011
- 5,307
yes input can be anything, one has to select what the input type is, what the functions are etc.
If we are talking about the external input, how the user (or the PLC) is controlling the VFD, you would have to choose a specific VFD model so we can talk about it, because there are all combinations possible. You can load stored settings using Digital I/O, or you can send various numeric values and triggers using PROFINET, you can use RS232 or RS485 to change parameters and so on..The input to what can be anything ? What controller ? Potentiometer? Really ? Digital signals ? What are those ? Where/how does networking play any role here ?
Hi,A modern air-conditioner will have a VFD to drive its compressor. The AC input will be rectified (and probably boosted by a power-factor controller) to give a DC voltage (usually about 400V) to run the VFD.
The right battery voltage connected to the right part of the circuit would mean neither VFD nor inverter would be required.
The PFC is simply a boost converter, so in theory would work with a DC input.
However, there may be other parts of the circuit that do run off AC (smaller fan, perhaps, condensate pumps etc.)
You mean modify the modern air conditioner?
"The PFC is simply a boost converter"
What DC input you think would be required?
Just because I know of aircons that are done this way, it doesn't mean that they all are. You'd have to look inside and see how it works.Hi,
Hi,Just because I know of aircons that are done this way, it doesn't mean that they all are. You'd have to look inside and see how it works.
A universal PFC front-end will generate the bus voltage from anything between 90V AC and 253V AC, so it should be quite happy at 120V DC.
They are usually referred to as being "inverter driven". But that might be the terminology they use to sell it to the British! Marketing-speak might not translate! The European Energy Using Products directive might mean that they all have to be inverter driven for efficiency.Hi,
Oh I did not mean to imply that they were all like that. Just wondering what your thoughts were on modifying one that we knew about already.
A good question might be how do we ensure we get a modern AC unit and not the old style. I see the old style still being sold too at 5000 BTU.
Yes. Most VFDs accept external DC input at their DC Bus terminals. Some provide input selection method in the parameters (Mitsubishi etc.) and some simply start working if you provide required DC at bus terminals. Mostly Chines models are a bit simple and free for input supply method.Hi.
What is the input ? What is the circuitry inside ? Does it rectify the AC mains and then creates another mains outputting a different frequency AC mains ?
If rectifies the inputted voltage first; could it be modified to accept DC as input and create AC at a certain frequency output ? Sort of selectable/variable frequency inverter ? Do they exist single phase output ?
Hi,They are usually referred to as being "inverter driven". But that might be the terminology they use to sell it to the British! Marketing-speak might not translate! The European Energy Using Products directive might mean that they all have to be inverter driven for efficiency.
Very few use a single phase motor version due to the problems listed above (#6).Yes. Most VFDs accept external DC input at their DC Bus terminals. Some provide input selection method in the parameters (Mitsubishi etc.) and some simply start working if you provide required DC at bus terminals. Mostly Chines models are a bit simple and free for input supply method.
VFDs come both for single phase and three phase output.
International models always come with select-able input supply frequency (i-e 50Hz or 60Hz) from within software through a specific parameter.
Yes VFDs are mostly designed for three phase but have seen single phase capacitor motors working very well with 3ph output. Might not be 100% perfect but somehow acceptable. Especially Chines versions are a lot more flexible. Western models are more sophisticated but with higher performance and safety.Very few use a single phase motor version due to the problems listed above (#6).
See this https://forum.allaboutcircuits.com/threads/powering-dd-motor-from-washing-machine-2.209818/Arent most modern laundry machines work on single phase VFD?
Assembly will never die | Programming & Languages | 18 | |
| B | Why are decoupling caps never aluminum polymer or tantalum polymer? | General Electronics Chat | 27 | |
The Dog That Never Barks | Off-Topic | 30 | |
Never seen this before! | Microcontrollers | 16 | |
AD620 simple connection with no input but the output never close to zero | Homework Help | 26 |
