Assembly will never die
cmartinez
Joined Jan 17, 2007
8,897
I find it kind of depressing that Assembly is becoming a kind of a lost art among newcomers to the industry. MCU's have gotten so fast and so powerful, that for most projects limitations regarding capacity and performance has ceased to be an issue. And so noobies are being drawn to easier to learn, and quicker to implement high level languages, But I believe that there are still many applications out there (especially for commercial gadgets and devices) that require the maximum possible optimization of resources to be economically viable. And only assembly is capable of that.
WBahn
Joined Mar 31, 2012
33,363
Of course there will always be applications for assembly language. If nothing else, the last jump in going from any high level language to executable code will almost always go through assembly language. And most processors have numerous features and instructions that can't be accessed via a high level language, so compiler and operating system developers have to deal with those via assembly. That assembly isn't being learned by noobies and, therefore, they aren't ready to do those demanding tasks isn't, by itself, an issue. They were never at a point to do those things as newbies, whether they "knew" assembly or not. That just means that those tasks are moving further into the realm of experienced developers which, in reality, they always were. What I am concerned about is that newbies, both hobbyists and students studying engineering and science, aren't getting the exposure to the underlying fundamentals of their craft, which will hamper them in eventually becoming those experienced developers down the road. It won't just be a matter of having to pick up assembly language at that point in time, but of a lack of the ability to understand and think about things at the needed level. Some will be able to overcome that deficiency, and become extremely valuable and highly compensated as a result, but most will flounder and not go any further -- and most of them will have no desire to do so, anyway.
cmartinez
Joined Jan 17, 2007
8,897
Exactly ... my concern as well
joeyd999
Joined Jun 6, 2011
6,561
The old art, like Rock & Roll, won't die.
It will (has?) become niche, and those of us who practice it will continue to be rewarded in our own unique, chosen way.
Rf300
Joined Apr 18, 2025
131
Some decades ago in the times of good old 8051, 8086, PIC and so on, it was really simple to write assembly code due to the simple architecture of those processors. Even a moderately skilled programmer could write an assemply program which was smaller and faster than a C program.
With modern architectures like ARM Cortex it is much more difficult to write good assembly code because you have to take into account things like pipelined register and memory accesses which may lead to penalty wait states and so on. Also the assembly language of an ARM Cortex is much more complicated and has more options than good old 8086 assembly. Nowadays the requirements for software are much higher (GUIs, touc screen interaction, ...) than 40 years ago. Therefore it is absolutely ineffective to write these things in assembler.
So assmembly language now has its justification and niche in areas where it is really needed like task management in operating systems or where you really need processor specific features.
Ian0
Joined Aug 7, 2020
13,317
The ARM is a RISC processor REDUCED instruction set. The 8086 isn't. ARMs have fewer instructions than 8086s.
Arm Cortex M0 has 56, 8086 has 81.
I've written lots of code for ARM Cortex, and pipelines and wait states have never even crossed my mind. It's no different to writing for an ATMega, except you no longer have to deal with carries and borrows when your arithmetic exceeds ±127.
schmitt trigger
Joined Jul 12, 2010
2,297
I can imagine the script of a futuristic dystopian movie.
“Once that his kids were safely tucked in bed, John went down to the basement. His wife was washing the dishes and silently glanced at him, with that look on the face of spouses who know better than to ask questions best left unanswered.”
“John gingerly removed the cover from a boxy plastic and steel artifact with the label in stylish letters: IBM. John punched a button and the monster came to life, his heartbeat consisting of different whirring noises. Suddenly, the glass screen, which had been totally dark, sprung to life, showing the cryptic message:
Starting MS-DOS….
C:\>ver
MS-DOS version 6.22”
“John let out a loud sigh of relief. The old trusty computer was still alive. Over 60 years after it had been assembled in a sprawling factory in Boca Raton, Florida. But for how long? Nobody could tell him with full confidence.”
“John knew he was working on borrowed time. So after pulling a long drag from his laser-sublimating E-cigarette, he said casually, perhaps to the Bill Gates photo hanging in a corner of the semi-darkened room; ‘Let’s go man, we have some assembly code to write tonight’ and started furiously clicking on the ancient keyboard, where the label on the ENTER key was just barely visible.”
dl324
Joined Mar 30, 2015
18,524
I learned assembly languages for 8080, 6800, PDP-11, and VAX 11/780 and have forgotten just about everything I supposedly learned because I never really needed to use them.
Rf300
Joined Apr 18, 2025
131
Cortex M0 is the simplest of all Cortex processors and was never successful. Cortex M4 has about 104, without DSP instructions. And the adressing modes are much more complex. I think the differentiation between RISC and CISC is meanwhile obsolete, since even "RISC" processors now hav a very complex instruction set.
35,322
Those are not simple in my books, except for 8051. If you want to see simple, see 6800, 6502, 6805, 6809, 68HC11, Atmel AVR, TI MSP430.
If you are going to create a C compiler, you are likely going to choose an architecture with the least common denominator. Otherwise, you need to write the compiler that is aware of enhanced features of the processor. Therefore it has to be processor specific.
For example, does the processor have n-bit shift instead of 1-bit shift?
Does it have byte swap?
Does it do single bit bitblt on memory locations?
Does it do floating point?
Does it have MAC, multiply and accumulate?
Does it do bit reversal?
... just to list a few.
35,322
my introduction was with a couple of CNC machines using the PDP-8 for control in assembly language
Same here. Worked on PDP-8/S, inside and out, including maintenance and repairs.
There were only 8 basic instructions:
I memorized the RIM (read in mode) binary code that must be entered via the front panel switches.
When you talk about it becoming a lost art, are you talking about new grads having strong experience with it or just learning and applying the fundamentals of it in school?
I'm a computer engineering student graduating in a few months. Assembly is a big focus of my degree but electrical and software engineering majors at my school get decent practice with it as well. I know that our computer science majors are exposed to it too but I'm not sure if it's to the same extent because they do digital logic and computer organization all in one course.
MrAl
Joined Jun 17, 2014
13,913
I know for a fact that we can build a very decent "Notepad" in assembler within 64k of 8 bit RAM. That's because it's been done already, and I used that program for a number of years with my old TRS-80 computer which was based on the Zilog Z80 CPU. It only had 64k of RAM so everything had to run inside that space.
There was nothing wrong with it and I could type and type and not run out of memory maybe because I did not need to type as many characters as I do today. That's not to say that I can't rebuild it into a disk storage plus RAM type editor where the text editor only sees a part of the entire file at any given time.
Heck, the Sinclair had only 16k and it could be used to edit programs in BASIC.
If we only have 3k of RAM for the editor itself, we also need RAM for the file we are editing, which means either all of the file stays resident or only part of it with the rest on disk. The editor windows parts of the disk file.
I did so much with assembler because at one time that is the only language I had, and the only language a company I worked for had at the time (very long time ago). We had to do industrial process control for one. I actually liked it. There were some higher level languages around at the time, but we had limited memory for the actual equipment we were building so asm was all we could use.
Things have changed so much now because turnaround time has to be faster. Can't spend time going over asm code hours on end like we used to.
Futurist
Joined Apr 8, 2025
952
These days a serious compiler project would be foolish not to leverage LLVM. Then one generates code for the abstract LLVM machine which has infinite registers and powerful generic operators. LLVM can then translate that generic (assembly like code) to almost any target with huge efficiency and optimization.
panic mode
Joined Oct 10, 2011
5,488
just stumbled on this thread. recalling putting together and playing with ZX81. shortly after that got spectrum 48k, and soon after that first PC (XT).
when it comes to assembly the most exciting time for me was the 90s when assembly demo scene was making big waves with visual and audio effects.
and who does not like good story like how Rob Barnaby made WordStar?
