Need to know if this freq Gen will give me a 2100hz signal over a 25mhz carrier
Steven Dixon
Joined Mar 4, 2017
25MHz Dual-channel DDS Arbitrary Waveform Function Signal Generator Specs are:
Frequency Range Sine Wave
Normal Modes: 0.01Hz~25MHz
Square Wave 0.01Hz~6MHz
Triangle Wave 0.01Hz~6MHz
Sawtooth Wave 0.01Hz~6MHz
Arbitrary Waveform 0.01Hz~6MHz
TTL Digital Signal Wave 0.01Hz~6MHz I'm using it on a old tube type 300 watt single channel ham Linear Amp
Steven Dixon
Joined Mar 4, 2017
What is the model number of the generator? What modulation method do you have in mind?
its generic on ebay
Model:
MHS-5200A Im trying to build a royal rife machine for cancer, it was built from an old 40's ship radio that would transmit almost any frequency over a adjustable 10 to 20mhz carrier. RF is my weakness in electronics, it needs the carrier to penetrate your body, they claim Mhz freq will penetrate 12" and audio only a fraction of an inch, and this tumor is in my lung and it needs to reach all your deep lymps. you think it would even matter what type of carrier. I'm pretty sure it was sine on the carrier and square on the audio. it works by using the resonant freq of the cancer and poof like the glass on the memorex commercial.
DickCappels
Joined Aug 21, 2008
10,661
Sounds like you want amplitude modulation.
The MHS-5200A will probably work as the modulation source.
What about the transmitter
