Hi forum
First of all, I'm a total newbie, so please bear with me, or direct me to the proper place, should this not be it.
My issue is this: I have a moped, which is limited to a certain top speed using a magnetic pickup placed by the rear wheel. This pickup sends pulses about the rear wheel rpm's to the CDI unit, which lowers the engine rpm's accordingly once the rear wheel reaches the set top speed. This one wire can be disconnected before the CDI, which causes the moped to run at it's designed top speed.
What I want to be able to do is, by a wireless relay, to either connect or disconnect this wire, thus enabling or disabling the limiter system.
So far I've received a two channel wireless relay from China, which will do the job. The problem is, that it will go back to disconnect state once I release the button on the remote. I need to somehow be able to click the remote once, and then the relay will stay in that position until I press the button once more. It seems that this particular relay isn't capable of doing that. Can I somehow add a SSR to it, that can do the job? I have some AQV101 SSR laying around...can I use them, or will I need to get med some other type of mechanical relay?
The China remote relay is 12V DC driven, and the relays have the following pins out: One is signal in, one is signal out, for when the button is pressed, and one is ground. I've currently configured it to send 12V DC + to the signal out, so that it can activate something that could do what I'm looking for. I hope I'm making sense, and that someone can help me with my little problem.
Best regards
Best regards
