need the help! -laser diode powersupply problem
Phan Phan
Joined Jul 30, 2018
I have a head laser belong to the coherent series laser diode V6051 FAP-81-30C-800-B. But the power supply has been no longer worked.
if anybody has knowledge about the driver of this diode laser, please help me design the driver.
Thanks so much!
RichardO
Joined May 4, 2013
2,270
This is going to be a challenge since it requires high currents (tens of amperes). Have you worked with high current amplifiers or power supplies before?
Phan Phan
Joined Jul 30, 2018
yes, in the past, this model worked with the high current amplifier. The threshold current of the laser 8-11 (A), and max current about 18 (A).
however, I am not a person that works in the circuits field.
I work in the optical field and application's high power laser.
If you have any ideal, please help me.
Thank you so much!
