Need some help to solve these problems.
BR-549
Joined Sep 22, 2013
4,928
If we have 0 volts on the bottom of the 3 ohm resistor and 12 volts on the top.....how much current is going thru it?
I see where this is going. Next you're going to want to know the current in the 1 ohm resistor, then the 6 ohm resistor, then the 2 ohm resistor, and the voltages at each end of those resistors--does it never end? :)
MrAl
Joined Jun 17, 2014
13,747
Well if the student does not know how to proceed sometimes more information has to be given.
I was thinking of giving a range of values, like say "the result at node 21 is between 10 and 11 volts" and then the student would have something to compare.
But i was asking for the way the student had done this in the past but didnt seem to get an answer.
BR-549
Joined Sep 22, 2013
4,928
Maybe something clicked and he solved it and left. Or maybe he got tied of my questions and saw no sense in it.
Or maybe he went to sleep like I didn't.
MrAl
Joined Jun 17, 2014
13,747
Can you guys calculate the answers for me so that I can check if my calculations are right?
So far I have got Vo in 07 is 60v.
Thank you.
Hello again,
The maximum voltage in figure 07 is less than 14v. That means 60v is way too high.
Can you solve this if we make both sources constant? That is, the source to the left is 10ma constant already, and make the right source 40ma just to quote some constant current. Can you solve it then?
That can get you started.
I might add that this circuit is just a little tricky but if we use straight forward nodal analysis we can arrive at a result. I also solved it another way but it is tricky because the two current sources interact with one being dependent partly on what it itself is putting out.
LesJones
Joined Jan 8, 2017
4,509
I think he just wanted someone to give him the answers to pass the test. I think he needs to go back over his school maths and science notes and re read his text books. (I am assuming schools still teach in a similar way to the way I was tought over 50 years ago.)
Les.
Nazmul Hossain Nihal
Joined Oct 19, 2017
20
Les.
Yes, I want the answers but I would also like to learn how to solve this kinds of problems.
