As the title states I'm just looking for help wiring up a single phase 115/230v cap start motor. I'll post a picture of the wiring diagram below off the name plate.
I'm wiring this motor up for cw rotation in 115v, connected all the leads to the appropriate terminal but I'm left with a yellow wire marked t4. There is no indication on the wiring diagram about lead t4 anywhere for either 115v or 230v. I've tried looking up the model number but can find nothing and I'm told that this is probably due to GE splitting off motor manufacturing after this motor was produced. The only slight indication of another lead in the wiring diagram is on the left diagram for 115v with thermal protection it says "ungrounded line" next to the ground terminal at the top, is this showing that the leftover wire ( yellow t4 ) should be grounded? Seems very vague to me so I thought I would ask the experts before going with trial and error.
