Need help verifying schematic wiring
tycoad
Joined Jan 22, 2025
10
I'm looking for some input on if these connections are correctly placed on the arduino, and from one to another. Any guidance or suggestions would be appreciated, thank you!
ElectricSpidey
Joined Dec 2, 2017
3,359
I didn't check your connections, but I did look at the LED drive section and I don't think that is going to work out too well for you.
Consider changing to a MOSFET with the load on the drain. (then correct in software if needed)
Of course, if you have something specific in mind with the drive section then just ignore this.
ericgibbs
Joined Jan 29, 2010
21,584
hi tyc,
With a 5V Collector supply and the LED's in the Emitter, the LED drive voltage will be approx 4V, across the diodes.
What colour are the LED's?
E
