https://lib.chipdip.ru/126/DOC001126730.pdf - Here's the data sheet.
Have breadboarded but can't get this to work. There's crackling and some buzzing some noise when i poke around, but signal isn't getting through. I think there are some fundamental concepts that I am missing
On page 5 of the linked data sheet useage notes it says - • Please connect only the ground of signal source with the signal GND of the amplifier in the previous stage. The problem is I don't as yet have a previous stage ( i plan on building a preamp). At this point I just have phono jack and guitar lead - just trying to get some noise to come out.
When you look at the Application example and Circuit/pcb example pattern on page 9, it shows that, especially on the pcb, that every resistor/cap on pins 5-9 are connected to GND (input) - which I interpret to definitely not be pin 3 of the chip (GND pin). I have interpreted that to mean the ground pin of my phono jack, i have just placed that on the line of my breadboard and then plugged in those resistors/caps to the same line a kind of floating virtual ground??. Also tried the ground rail on my breaboard with pin 3 of the chip connected, didn't work either.
As for the volume pot..I'm confused about that as well (surprise surprise
Normally I would connect the signal to centre pin of pot, run a wire to the input, and other to gnd rail. Could I still do it that way?? Or should I use pin 9 which is a dedicated volume pin. How would I use pin 9..my guess is that you only connect 2 pins of the pot, but which 2 and how?
Could anyone tell me what I'm doing wrong here. I have 8ohm speaker attached, with a 7.9v supply, no heatsink but chip not really getting warm as yet.
I do have a heatsink for the chip, and eventually plan to run at 12v.
any help, much appreciated.
cheers
Steve
cheers
Steve
