Lestraveled
- Joined May 19, 2014
- 1,946
OK, The voltage that powers the chip enters on pin 2 and 3. If everything was working you would read about 15 volts DC across pins 2 and 3. You measured 1.6 volts DC, in an earlier post. So, why is this the case?? Either the circuit that supplies the chip with operating voltage is bad, or the chip is bad and is drawing a lot of current, keeping the voltage low. You measured 69 volts across the 6500 resistor, which implies the chip is drawing 0.010 amp. So, it does not appear that the chip is drawing excess current. You measured .8 Vac across 2 and 3, so the two 22uf caps are not open.
Hmmmmm......
Using the "diode" setting, measure both directions, of the SMD diode.
Hmmmmm......
