So I am a bit of a novice still when it comes to this but I know enough to get rough ideas. Currently I am designing a foldable and semi-flexible solar panel and a battery bank with 16 18650 3.7 3000 mAh batteries. These are the cells I plan on using
http://m.ebay.com/itm/181803913088?_trksid=p2385738.m2548.l4275&_mwBanner=1&varId=480750586068
The plan is to have 12 of them running in series with a 1N914 blocking diode on the positive wire giving me an max output of 31.2W, 5.4V, and 5.8A . The problem is the amperage is to high, The batteries have a max change current of 4A.
As for the battery bank it's 16x 18650 3.6V 3000mAh in parallel giving me 48000mAh. Here is the controller .
http://m.ebay.com/itm/Dual-USB-5V-1...er-PCB-For-Phone-DIY-/171659961777?nav=SEARCH
And help or suggestions are appreciated.
