Need help with sallen key bandpass filter
alialiali
Joined Dec 12, 2008
26
I did changed the TL072 (wich has a bandwidth of 4 Mhz)
to a LF357 ( wich has a bandwidth of 20 Mhz) I changed all of them, but nithing happend the result is the same !!
bertus
Joined Apr 5, 2008
23,026
When you look closely at the curve of the filter, the lowpass does not come from the 0 dB.
The software will calculate a higher frequency as expected due to this offset.
Greetings,
bertus
Joined Apr 5, 2008
23,026
I think the two frequencies of 23 kHz and 53 Khz are to close together to get a 0 dB point in between.
You could try to change it to chebychev chacteristics in stead of butterworth.
I do not know the software you are using.
Greetings,
Audioguru
Joined Dec 20, 2007
11,248
Your filters are only second-order so their slopes are not sharp. The 53kHz lowpass also cuts 23khz a little. The 23kHz highpass also cuts 53kHz a little.
Their frequencies are too close together and with the not-sharp slopes then they affect each other.
