That chip can work down to about 0.007 volts without modification.At 6V, the difference between pass and fail is only 0.10V. Can this chip (TLV1702) work that close?
Thanks everyone for all your help. I finally put the order in for the project parts (~50) so I should be getting the chip in a few days. The only bad thing is that they don't seem to make a DIP version of the part so breadboarding will be impossible without some sort of breakout board. So I decided to go ahead and make it into the main board. I can tweak the resistors once its built.That chip can work down to about 0.007 volts without modification.
That's why I sent you a link to 41 choices. Two of them are through-hole.The only bad thing is that they don't seem to make a DIP version of the part
I wasn't able to find any DIP versions of theTLV1702 which is what I thought you said to use. I didn't want to get a different part because I might get one that was more like the 741 than the 1702.That's why I sent you a link to 41 choices. Two of them are through-hole.
