so the cutouts I want to but have a on-off-on toggle switch, which I don't want to use, doesn't match the interior of the car (LOL)
basically how it works, push the toggle one way it opens the valve, push the switch the other way it closes the valve, and when left in the middle, there is no power draw.
what I want to do is use a single push button momentary switch that when pushed down it will open the valve, when let go it will not draw any power and then when pushed again momentarily, it will close the valve. I've been told to look into dpdt relays, but the way I see it, once the switch is released, the relay will release (not helping me at all). then I hear about latching relays, but the way I understand it is that once I release the button the relay stays latched until the button is pushed again. which doesn't help because then its sending power to the drive motors, and I don't want to burn out the motors.
I've tried looking into timer relays, but there seems to be like 20 different timers to choose from and I have no idea which one I need. I'm so lost lol
can anyone help??
can anyone help??
