Need help with MOSFET tests and repairs
gamerguy
Joined Mar 7, 2014
2
Hello everyone,
I am trying to find out the issue with my gaming graphics card which is not showing any display. I checked the voltage of both GPU and
memory with the help of a multimeter(the card has built in point for checking voltages). They are running at optimum level. So I thought of checking the MOSFETs first.
I could find 4 big MOSFETs and about 12 smaller ones.
The bigger ones are P0603BD(x2) and P0903BD(x2) (both are n-channel).
(These seem to be the datasheets for them P09 P06)
Anyway, I checked the resistance between the source and drain(by multimeter) for all the four of them by connecting black to the Drain
and red to the Source.
When multimeter was set to 2000 Ohm,
The P09s gave reading of 535 and 511 Ohm
The P06s gave 130 and 002 Ohm
When multimeter was set to 20k Ohm,
The P09s gradually increased till 6.28k and 11.2k Ohm respectively
The P06s gave 0.11k and 0.00k Ohm
What do these results indicate? Is any of them dead? Do I need to run any more tests?
Please let me know if any more details are needed as I am a total n00b in electronics. It's been a long time since I last studied them.
Thanks in advance.
18,184
Without controlling the gate voltages, I don't think your tests mean anything. :(
I'm not sure you can test on-board, except for MOSFETs that have failed to a dead short. You may need to remove them first.
gamerguy
Joined Mar 7, 2014
2
Hi. Thanks. I'm extremely sorry for the late reply. I had some health issues.
Anyway, if I manage to remove the MOSFETs from the card, what tests should I conduct to determine whether it is working or not?
Flug540
Joined Mar 24, 2012
60
I just built myself a simple MOSFET tester last night. Basically I'm supplying voltage to the gate through a switch and connecting an LED with a resistor in series to the drain. Simple and effective.
Another thing I would check is big electrolytic capacitors. They tend to go bad with age.
praondevou
Joined Jul 9, 2011
2,942
Do you have a multimeter?
You could test:
1. Body diode through a diode test from source to drain
2. connect a power supply/battery with a lamp, LED/resistor or any other load in series with drain/source. Then control the gate with a for example a 9V battery. + to gate, - to source.
I would connect a resistor of anything between 10k and 100k between gate and source while handling it. Don't leave the gate floating, it's ESD sensitive. Also, the gate, once charged needs to be discharged in order to switch the MOSFET off. You can short gate source (if you decide not to use a resistor)
ian field
Joined Oct 27, 2012
6,536
You can precharge the gate capacitance with nothing more than a continuity checker. That will either turn the MOSFET on or off depending on polarity - that of course can be tested with the same continuity checker.
Some continuity checkers are more sensitive than others - you can get a 2 LED type with a PTC resistor for indicationg any voltage from 4 - 450V, and contain a tiny 12V battery for continuity - the one I have shows a glow with about 22k resistor.
With such a checker, any leakage is a fail - the MOSFET will be either on or off depending which way you charge the gate capacitance.
Even my checker might not show "fail" gate leakage - but if you charge the gate to make the drain/source conduct and the gate charge leaks away - that's a fail.
