Need help with molex
faloompa
Joined Jan 27, 2020
6
I want to connect an addressable RGB led strip to female molex of a computer PSU cable. I want to solder wires to the 5v and ground connection on the led strip and on the other end add two male molex pins to plug to the female connector(I know molex also has 12v and another ground but I won't use them). In order to do that I'll need the appropriate items which are: suitable wires, molex male pins and crimping tool. I've never dealt with molex so I need your help with finding those 3 correct items and that they will be compatible with each other. Could you please write the exact name of the items I need and send link from eBay or Amazon? (Maybe molex male pins have different sizes, maybe I need a specific crimping tool for it.. etc)
Thanks!
dl324
Joined Mar 30, 2015
18,326
Welcome to AAC!
It would be helpful if you specified which Molex connectors you're talking about. Molex was a company, now part of Tyco IIRC. They had many styles of connectors.
My apologies to Molex. Stories of their demise must have been a figment of my imagination...
https://www.molex.com/molex/products/group?key=wire_to_wire_connectors&channel=products
faloompa
Joined Jan 27, 2020
6
The crimping tool would be expensive for just two pins. If you wanted you could just squeeze the contact around the wire and then to ensure a good connection carefully solder the wire into the connector.
The pins should be 0.093" diameter.
You can also get the pins pre-crimped onto a piece of wire. For instance: https://uk.rs-online.com/web/p/pre-crimped-leads/1260306?cm_mmc=UK-PLA-DS3A-_-google-_-CSS_UK_EN_Cables_And_Wires-_-Wire_To_Board_Cable_Assemblies|Pre-Crimped_Leads-_-PRODUCT_GROUP&matchtype=&aud-821594433763:pla-394495661468&gclid=EAIaIQobChMIjuHj2r2k5wIVgbTtCh1zBwwFEAQYBCABEgK5tfD_BwE&gclsrc=aw.ds
Yes! Exactly the details I needed. But I want to ask a few things:
If I plan to get a 1m 144 leds strip, I'll need a better wire than 18 AWG right? 18 AWG has 7 ampacity and 144 ws2812b leds would require 0.06*144 = 8.64 amps. Also, what about this cheap crimping tool: Molex Style Crimp Tool.
This is the (sort of) diagram of what I want:
jpanhalt
Joined Jan 18, 2008
11,087
Your drawing has an obvious flaw: The data line and power line have to have a common ground. I did not see that explicitly stated in your first post. Remember, data is a series of highs and lows. Both have to be relative to something.
AlbertHall
Joined Jun 4, 2014
12,625
There is no absolute figure for how much current a particular wire diameter will handle. It depends on the insulation (how thermally insulating it is, what temperature it will stand), how much opportunity there is for heat to escape, and the ambient temperature it needs to operate in.
I have no experience of that crimp tool. If you use that one then get a good surplus of crimps as you will likely wreck a few.
faloompa
Joined Jan 27, 2020
6
thanks! and one more thing before I buy the crimper: Does it looks to you like it has the correct shape for crimping those 0.093" molex pins, is this the correct tool I'm looking for (regardless of quality) ?I've never used this tool before and I just want to know if this is how the molex crimping tool should look like
AlbertHall
Joined Jun 4, 2014
12,625
I don't know how well this will do. A 'proper' tool ensures correct crimp pressure and would have two separate crimping sections, one for the conductor and one for the insulation in one action.
