Need help with microcontroller chips.
johnnyinwa
Joined Jun 24, 2013
61
What is the difference between a pic12f635 and a pic12f635-e/p? What is the difference between a pic12f635 and a pic12f635-i/p? Will a pic12f635-e/p or a pic12f635-i/p work in a circuit that calls for a pic12f635? Thank you for your help.
MrSalts
Joined Apr 2, 2020
2,767
The trailing letters/dashes/numbers are usually package (through-hold or various SMD packages. Or, indicating temperature range - commercial vs industrial vs military ...
Check the datasheet, all sub-species are typically listed.
35,088
You cannot order a PIC12F635. This is just the generic name of that family.
You have to specify the full part number, e.g. PIC12F635-I/P or PIC12F635-E/P.
For your concern, the two are identical.
The I stands for industrial temperature range, -40°C to 85°C
The E stands for extended temperature range, -40°C to 125°C
tepalia02
Joined May 13, 2022
37
Suffixes do not matter that much. Both serve the same purpose.
AlbertHall
Joined Jun 4, 2014
12,651
From the datasheet, 'i' is industrial temperature range, 'e' is extended temperature range.
Other letters indicate the package, 'p' is DIP.
