Need help with DRV8830 / leak current when VCC is turned off
akke
Joined Dec 17, 2015
77
I have a prototyping PCB with 2 LDO's on it where one main LDO is running the board's CPU at 3.3V.
There's a second LDO (LT1129CS8) running at 6V to drive a 6V motor using a DRV8830 chip.
This LDO's SHDN pin is driven by the CPU's 3.3v pin to turn on/off the 6V power supply to the DRV8830. The idea was that this way we can get lower power consumption. The LDO should be at approximately 15uA when it's in shutdown.
Now, the problem is that when I turn off 6V power supply to the DRV8830, there seems to be a leaking current between SDA/SCL and GND of about 400uA.
For testing I have the DRV8830, a couple of capacitors and a 3.3V CPU on my breadboard. As soon as I connect SDA or SCL to the CPU I see the power consumption increase about 400uA. When I disconenct GND from the DRV8830 the power consumption is gone too.
Maybe this DRV8830 doesn't like power on it's SDA/SCL pin when there is no power on VCC?
But I'm not sure how I can fix this and get the low power consumption that I was planning ...
akke
Joined Dec 17, 2015
77
I was just testing. If I connect the DRV8830's VCC pin to 3.3V the power consumption immediately drops too. So maybe I need to somehow connect the VCC pin to 3.3V when 6V is not available? but how can I do that safely?
