Need help with circuit design for a 12 Vdc solenoid and Imax is >3A.
Ernest29
Joined Feb 7, 2018
10
Hi Guys I'm trying to do a simple project . Im using a solenoid 12 VDC and max current is >3 A . I would like to include a capacitor so that the capcitor stores the charge and operates the solenoid for 3-4 sec even if the power supply is cut off . Can any one help me with a circuit diagram and values ?
Ramussons
Joined May 3, 2013
1,567
Is it a one time project?
Can you find out at what voltage the Solenoid drops out?
The one can work out a rough idea of the capacitor required.
Tonyr1084
Joined Sep 24, 2015
9,744
3 amps is a lot of current for a capacitor to provide while maintaining sufficient voltage to hold the solenoid active for 3 to 4 seconds. I've done some work in Naval Power Systems and the sort of cap you'd need is going to be rather large. It all depends on how much voltage the relay needs to hold it active. Without that information I don't think anyone can do better than a guess at what you need. Perhaps a 3 farad SUPER cap may hold sufficient energy to do the trick, but like I said - it's all guess work until we know all the parameters. But they are typically very low voltage. So to get the voltage you'd need you'd have to place a number of them in series to handle the voltage.
ericgibbs
Joined Jan 29, 2010
21,412
hi Tony,
A point he should also consider is the required recharge current, I guess his PSU will trip its current limit.
E
Tonyr1084
Joined Sep 24, 2015
9,744
@ericgibbs Good point. Hadn't thought about what's supplying the 12 volts to begin with.
Sounds to me like the thread starter just wants to keep a solenoid active for a few seconds in the event a power failure occurs. Sometimes an interruption can last just a second or two and keeping the solenoid active may prevent some sort of loss of control.
OR perhaps he wants to send a command to the solenoid and then have it self sustain for that short period of time. Without more details we're just guessing at what may be needed.
I'm SURE there's a solution. Possibly a better solution. But we need to know all the details and the goals.
AnalogKid
Joined Aug 1, 2013
12,077
I don't think a 12 V solenoid will hold in all the way down to 1 V. 9 V is more realistic, 8 V if you feel lucky. According to Bordodynov's plot that means three 3 F caps in series.
ak
AnalogKid
Joined Aug 1, 2013
12,077
Interesting part, very expensive.
AND, the only hint about its ESR is at 1 kHz: 4 *ohms*. At three amps, that is the entire 12 V dropped inside the cap, with nothing for the solenoid.
ak
