Need help with basic transistor switch
RobbJohnson
Joined Dec 15, 2009
76
On the test point I am looking for 0 to 10v signal. The part of the circuit that is indicated by S1 actually is come comparaters and nor gates witch result in Either gnd or +15v or gnd. The Charging circuit is actually a constant current cuicuit feeding C1 via R10.
My problem is the signal nevver reaches 0 volts (as shoun on the trace. I can compensate in the comparator for this), but I really want 0 volts. Changing the 1k (R3), but that changes the decay rate and the current.
Does anyone have any sugestions?
17,498
I think you could add a pulldown resistor, maybe 5K or so, to help pull it down a bit more. Testing is needed.
If you manually pull S1 to ground, do you get the result you want? What voltage do you see at S1 when it's only pulled low by the comparator? I'm a little surprised that's not low enough.
RobbJohnson
Joined Dec 15, 2009
76
I need the Cap to discharge to 0V via the Transistor when told. Once the comparator sees 0v (not 0.0001 or above) it will turn off the transistor allowing the Cap to charge.
Ron H
Joined Apr 14, 2005
7,063
The way I have solved this problem in the past is to turn off the current source with the same signal that turns on the switch. A small MOSFET in place of the NPN will also be an improvement.
RobbJohnson
Joined Dec 15, 2009
76
Ok, Would this make it easier, using the op amp can we offset this down to zero. may be even amp it up by 2 volts and then lower the bottom to zero?
RobbJohnson
Joined Dec 15, 2009
76
Ron,
Turning off the source will not discharge to capacitor. may be a combination of both, but i wounder what will happen when the collector voltage becomes so low that the transistor turns off. I'll play with that. thanks.
panic mode
Joined Oct 10, 2011
2,759
not quite sure what you are after but you do have dual supply so you can connect emitter to -15V instead to ground. then you can get not just zero but also negative output if you so desire.
RobbJohnson
Joined Dec 15, 2009
76
Panic mode,
First thing I tried, but conecting the emitter to -15V stops you fron turning off the transistor and allowing the circuit to recharge.
Something else I need to Do?
Don't forget my switching voltage (on the other side of the base resistor) is 0 and +15
I am probely just missing something.
Ron H
Joined Apr 14, 2005
7,063
I thought you said you had a constant current source. All I see is a resistor charging a cap, a transistor discharging the cap through another resistor, and a voltage follower. It is important to post your actual schematic, not a simplified version of it.
What I meant was, turn off the current source (if you have one) at the same time you turn on the transistor discharge switch.
RobbJohnson
Joined Dec 15, 2009
76
Ron and all.
Here Part one of the Circuit so far. R46 and R47 ofset the comparator so it detects a voltage above zero (to make the circuit work). But as i explained before I really wanted to be Zero, Grounding U3 pin 3 would be better.
This circuit does work, just trying to tweek it to a point I would like it to be.
CDRIVE
Joined Jul 1, 2008
2,219
I assume Q1 is your constant current source. This is not a solution to your problem but isn't the emitter - collector of Q1 wired back wards?
BTW, the suspense is killing me.. Are you building some sort of scope sweep?
PaulEE
Joined Dec 23, 2011
474
Without knowing much about your circuit in particular, I've found that transistors work far better at switching things on and off when they are the bottom element and the top is either an active load or resistor. In this way, a worst-case base current estimate based on a crappy beta value (like 10 or 20 for the 2n2222) can be injected and the transistor will saturate and shunt your output signal to ground more effectively than if the resistor were on the bottom. If you can't work with that circuit because it inverts the signal, simply add a second stage; same style as the first. My 2¢.
RobbJohnson
Joined Dec 15, 2009
76
This is Crazy, the circuit is working with the transistor the way we think it should be, But the simulator only will work with it in as the schetmatic says. The simulator schetmatic was drawn in error and since it worked i didn't catch it.
Now i have to figure out whats going on there. (Mulisim 11)
Yes, I have a 2 channel bit scope and was playing around with sweeping audio circuits.
Mainily, jsut love the chalange of elcetronics.
Ron H
Joined Apr 14, 2005
7,063
Swap the emitter and collector on the PNP. The reverse beta is high enough for the transistor to work as a current source, but it is far from optimum.
The attached circuit has a transistor added, to turn off the current source during the ramp discharge time. In simulation, the ramp reset voltage was about 6mV. It will probably be different from that, how much depends on how well the 2N3904 model matches reality.
CDRIVE
Joined Jul 1, 2008
2,219
This approach is what Ron mentioned earlier.
http://forum.allaboutcircuits.com/showpost.php?p=448425&postcount=4
I spiced this using a PNP but you will have to lower the V+ voltage to the current source and compromise with the values of R5 & R6 for it to work. On the up side PNP's are much easier to find. The other one is switched with a PFET.
Note that I made no attempt to choose the best P Chan FET for this. If you decide to go this rout someone should be able to tell you the best FET for this application.
Chris
Ron H
Joined Apr 14, 2005
7,063
Chris
When the current source is turned off, the cap discharges through the NPN as before, but there is an additional path through R1 and the PNP's collector-base junction. This might not be an issue.
At this low frequency, this technique might be OK, but at high frequency (low values of C1), Having the entire current source transistor moving from basically zero volts to near Vcc will probably be a problem.
Of course, my circuit has high speed problems too, due to transistor storage times, but I have used similar concepts at relatively high speeds.
SgtWookie
Joined Jul 17, 2007
22,230
Are you really using 100 Ohms for R5? That would be asking the LM311 to sink 150mA current when it's only designed for 50mA max! :eek:
BTW, nice to "see" you again, Robb - how's the tank coming? :)
RobbJohnson
Joined Dec 15, 2009
76
cdrive and others,
This is what i was looking for. while not at 0v it's close and i can live with the voltage divider on the comparitor.
Thanks again for all the help
Robb
RobbJohnson
Joined Dec 15, 2009
76
No, 100k, amazing how many errors crop up when you play with a circuit.
Tank is still on the bench, Got two sets of worm and gear made so it dosent free wheel. Modifing the track and will be ready for another road test. Hoping not to have to go to larger motors. Your circuit sugestions are still working.
Robb
CDRIVE
Joined Jul 1, 2008
2,219
Ron, I like your approach much better than mine. As Paul stated,.. it's usually easier to low side switch than hi side. ;)
Regarding the speed issue at high rep rates you mentioned: I guess it could be sped up with a small cap across the 100K base resistor.
Chris
