Need help with an inverter
JonathanL
Joined Jun 12, 2020
5
Hi guys
I am having trouble with an inverter the link to actual inverter is below. When i wire it up and try run it in auto it does nothing. I can run it in local mode and it is ok but when I switch to auto it does nothing. For a quick test i have put 24 volts onto terminal DL1 and it wont run. I have changed the settings on the inverter to suit the standard macro and 3 wire macro from the manual on pages 57 and 58 but it still wont run. I am assuming because it runs in local that it will run in auto and that i am just missing a setting but i cannot seem to find it and it could be something silly but i cannot find it. Any help would be great.
Thanks guys
https://ie.rs-online.com/web/p/inverter-drives/6211284/?relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D626572266C753D656E266D6D3D6D61746368616C6C26706D3D5E2828282872737C5253295B205D3F293F285C647B337D5B5C2D5C735D3F5C647B332C347D5B705061415D3F29297C283235285C647B387D7C5C647B317D5C2D5C647B377D2929292426706F3D3126736E3D592673723D2673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D36323131323834267374613D3632313132383426&searchHistory={"enabled":true}
