Need help with a sequential circuit
panic mode
Joined Oct 10, 2011
5,431
two inputs marked X are not a problem (just tie them together, this is common representation). two outputs marked Y is clearly an error. they should be Y1 and Y2.
one of them is combinational output, other is sequential.
the only time where two active outputs (not tristate) can be tied together is when using wired AND (requires open drain/collector output). if this circuit is part of the question, then such output design must be clearly mentioned.
kainotk
Joined Mar 31, 2009
10
Thank you.
The second part of my question is with the sequential part of the circuit.
It's clear at the output y (from the 3-input OR) that a x' will cause y = 1 (a "0" is detected), then what is the purpose of the sequential part of the circuit?
33,325
Thank you.
It looks to me like this is a deliberately convolute circuit that does the same thing that a much simpler circuit could do.
If you track through the states (and assuming I did it correctly) then you will discover that the output is a 1 if either the present input is 1 or if the input was 1 at the previous rising clock edge. So it's not quite the same as just an inverter, but it is very close to it.
