Need help with a max1771 design
illayaraja
Joined Oct 6, 2015
12
Hi...
I need to generate 100V @20mA using max1771 and i want connect 1k to 10k load it's ?..... plz give me any ideas?
Moderator note: The first three posts of this thread were moved here from a highjacked thread.
illayaraja
Joined Oct 6, 2015
12
Hi fnds........
I need to generate 100v @ 20mA it's possible to do ?...i'm using max1771 in my circuit i got 100v but while i'm connecting load it i'll goes 50v @54mA ....i want connect 1k to 10k load
bumba000
Joined Oct 7, 2015
97
I do have three of these tantalum caps available (https://www.digikey.com/product-detail/en/TAP336K020SCS/478-1895-ND/563998). Put them in parallel and it didn't help. So, I pulled a couple of aluminum polymer caps (these ones http://nichicon-us.com/english/products/pdfs/e-l8.pdf) from a good video card and it doesn't seem to have helped. =0(
The caps are the 6.3v 560uF version.
Also, I'm not sure what it means just yet but I've found out that the PWM speed is actually 500Hz. I see that you've mentioned the inductor's resonance should be 5x greater than the switching frequency. I don't know what switching frequency means but I'm assuming it's the PWM speed. Which would mean that the inductor resonance should be about 2500? I feel so lost. I am finding resonance is when inductive and capactive reactive are the same?? Oh my goodness.
Help please. Unplugging solder iron, multi meter off, lcr meter off, head on pillow...
Alec_t
Joined Sep 17, 2013
15,119
First, you need to post a schematic of your circuit.
:confused: A 1k load on a 100V supply will draw 100mA; not the 20mA you specified.
Google will help you regarding PWM.
illayaraja
Joined Oct 6, 2015
12
I'm using same circuit .....switching frequency 60khz
while input 12v E=80%
while input 9v E=40%
my inductance 100uH
