I've got a problem with a part of an automotive circuit. It seems like it should be easy, but I'm missing the boat on it.
Input voltage nominal 12 or 24 volts (13.5 to 26 volts). I need an output voltage that is 10 volts below the input voltage and floats with the input. The use of the circuit will be the "ground" for 2 mosfet drivers that will drive p-channel mosfets. So the circuit will have a small negative current.
I tried using a floating negative voltage regulator as per the attached image. But it didn't work as expected. See image:
Anyone have some bright ideas on how to achieve this? I think there is a simple solution, but it is evading me.
Thanks.
Thanks.
