Need help with a diode circuit problem
Jony130
Joined Feb 17, 2009
5,600
Hi, to me your solution is wrong .
For Vd = 0.7V diode current is equal to
Id = (4*0.7V + 5*0.7^2) = 2.8 + 2.45 = 5.25mA
And resistor current
Ir = (5V - 0.7V)/200Ω = 21.5mA
So Id is not equal to Ir. and this means that your solution is wrong.
And the correct answer is Vd ≈ 1.51V because this time
Id ≈ 4*1.51V + 5*1.51V^2 ≈ 17.4405mA and Ir = (5V - 1.51V)/200Ω ≈ 17.45mA
And since Id≈Ir we have a correct solution.
Additional I plot Id vs Vd and load line
copper_pipe
Joined Sep 30, 2014
18
230 V * 1/5 = 46Vrms on the secondary
Output pk voltage will be 46 * sqrt(2)/pi = 20.70V = DC
RMS = 20.70V/2= 10.35V
P = I^2 * R = Vrms^2/R
P = 10.35^2/10 = 10.71W
Does this look correct to you guys?
