I'm trying to make a counter that counts down from 9 to 4 (9-8-7-6-5-4) then returns to 9 and so on. I managed to set the max to 9 but I don't know how to use the TC pin (pint 12) to set the minimum. Can anybody guide me on how to use the TC pin?
It's not that I tried something that doesn't work, I don't know what to do with the TC pin it's supposed to control the max/mix values right?Welcome to AAC!
Post a schematic for your circuit and show what you've tried that didn't work.
Have you read the datasheet?I don't know what to do with the TC pin it's supposed to control the max/mix values right?
Didn't Proteus flag the two outputs that you have shorted together?It's not that I tried something that doesn't work
01xx OR x100 makes perfect sense in some alternate universe.Why is U7 an OR gate?
1. On startup:It's not that I tried something that doesn't work, I don't know what to do with the TC pin it's supposed to control the max/mix values right?
