need help understanding schematic
moheddinebouajilavrx@gmai
Joined Apr 9, 2024
3
I'm relatively new to the world of electronics, and I've stumbled upon a schematic diagram that's been giving me quite a headache. I was hoping some of you experienced folks could lend me a hand in deciphering it.thermou.PNG
LowQCab
Joined Nov 6, 2012
5,101
This is a useless Schematic.
It will continuously oscillate, and not provide any useful function.
( Unless it's supposed to provide some sort of special PWM-Output )
Why don't You simply state what You are trying to achieve, ( in detail ) ?
Joined Apr 9, 2024
3
hello sir and thank you for reply . i want to creat a baord with an atmega1280 chip and a k thermoucoples and ihave to amplifie the signal from the k thermou so it can be read by the atmega
Irving
Joined Jan 30, 2016
5,195
If you want to do this easily and quickly use a MAX31855 IC connected to the ATmega1280 via I2C 2-wire interface . Don't waste your time, money and sanity messing around with discrete op-amp & ADC solutions, you'll be in a world of non-linearity and drift and the chances of getting a useful reading are minimal... been there, done it.;..
12,243
am i missing something?
No.
R338 is not part of a positive feedback loop. Don't let the terrible schematic technique confuse things. R338 is the normal connection from the non-inverting input to GND is a fully-differential opamp circuit.
Also, one end of C305, C306, and all four diodes is grounded. All of that is a single-pole lowpass filter with bipolar transient protection clamping to approx. 0.2 V.
