Need HELP - Turn Signal / Hazard Lights with Astable 555
Status
Not open for further replies.
juddcharlesw
Joined Nov 27, 2013
5
I am attempting to simulate a hazard light/turn signal combo with a 555 astable timer and one clocked J-K flip flop, as seen in my schematic attachment. I need them to flash at different rates, hence the 555 to create a slower waveform. I am using the slower flashing rate from the 555 to drive the turn signals.
I have both signals working independently at the slower frequency, and additionally have the hazard lights working at twice the speed of the turn signal flash. The problem is, when the hazard lights are flashing, I need the turn signal function to be disabled. Currently when the hazard lights are flashing and I turn on the turn signal, the slower waveform from the turn signal is seen in the LED output as well.
I'm sure there is some simple logic here that I'm missing, but I just can't put it together. Designer's block! Thanks so much for any help you can offer.
Wendy
Joined Mar 24, 2008
23,848
The owners of All About Circuits has elected not to host discussions of automotive electrical system modifications/enhancements due to safety concerns, the potential of legal ramifications and the possible circumvention of vehicle regulations at the state and federal level.
This thread is against the AAC forum rules, Chapter 6, as seen here:
6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This can be found in our Terms of Service (ToS)
Automotive modifications of any kind are strictly forbidden. Therefore, this thread will be closed.
Please try to understand the reasons behind this action, and feel free to browse and use the forums.
You might find answers to your questions in one of these forums:
http://forum.allaboutcircuits.com/showthread.php?t=54400
Another good forum that shares many of the same membership is http://www.electro-tech-online.com/ . Good luck.
Status
