Need help to double check with supply stage of circuit
floxia
Joined Mar 7, 2023
22
I have designed this voltage regulator circuit although I am not sure if I have connected the bridge rectifier for reverse polarity protection correctly.
I am confused about whether this is the right way to connect it and the datasheet doesn't much about it.
I am open to any suggestions, and any help will be greatly appreciated!
Datasheets:
5A Fuse
Rectifier
LDO
Circuit:
floxia
Joined Mar 7, 2023
22
Yes, the bridge is only used as a reverse polarity protection (not as an AC rectifier) so regardless of which way you plug the DC supply, it will always be correct. I have seen it implemented in a few circuits although I am not sure which way is the correct one, I have tried to reverse-engineer it from a circuit I have but it's hard to tell which pin is which. :confused:
35,071
You don’t need bridge D5 if your input is already rectified DC.
However, including it provides protection from reverse polarity with some voltage loss.
StefanZe
Joined Nov 6, 2019
212
It is now connected the right way for your purpose
floxia
Joined Mar 7, 2023
22
OK,
This is the PDF datasheet for the DF02M, it shows the pin details'
E
Thanks for doing some research, I did have a look at Vishay's datasheet although I was not sure, that the configuration would have been the same!
You don’t bridge D5 if your input is already rectified DC.
Yes, you are correct, I will only be using it as reverse polarity protection.
Perfect, thanks for clarifying this.
Thank you all for taking the time to answer, I have a curiosity now for future designs, when using a rectifier for reverse polarity protection the AC input will be connected to the DC source and the + would be positive voltage and the - the ground, is this correct? Because looking at the datasheet posted by Eric, that's what I understand.
StefanZe
Joined Nov 6, 2019
212
Yes.
StefanZe
Joined Nov 6, 2019
212
Just one more thing. The DC source ground and the ground after the rectifier are not the same. This could lead to some problems if your design is connected to other devices with the same DC source ground.
38,721
If you wanted to avoid the bridge diode voltage drop, and just block reverse voltages, you could use a power MOSFET.
The MOSFET drop when conducting is just its on-resistance times the current.
dl324
Joined Mar 30, 2015
18,453
Datasheets:
5A Fuse
Rectifier
LDO
Why are you using a 100uF filter cap if the input is DC? Why are you using a 5A fuse on a 500mA regulator that has built-in protection? The fuse symbol doesn't make it obvious that it's a PTC fuse.
Technically 78M05 isn't a low dropout regulator. LDO's have dropout voltages in the several hundred millivolt range, not 2V.
floxia
Joined Mar 7, 2023
22
After reviewing the circuit, I have decided to replace the 7805 with an SPX3819 which is a better LDO and will help to keep the noise low while being cheap, this is the circuit now:
(VCC is actually meant to be VDD, and on VIN 1 is GND and 2 is +12)
The enable pin is tied to Vin as per datasheet schematic:
The datasheet mentions where to put decoupling capacitors, but not the recommended capacitance, after looking around, I have found a few circuits using 10uF capacitors, will 10uF be too large for the purpose?
28,113
Why do you insist on calling 7805 an LDO regulator? It never has been and never will...
EDIT: corrected punctuation
It is not obvious to many folks that there is a difference among regulators, or even what LowDropOut implies. So some assume that it means something about reliability rather than capability. And some folks have never suffered from regulator dropout.
StefanZe
Joined Nov 6, 2019
212
to clear up the LDO thing,
Both the 7805 and the SPX3819 are linear voltage regulators, but only the SPX3819 is a low dropout linear voltage regulator. The dropout voltage of the 7805 is around 2V and therefore not considered a LDO (compared to the SPX3819 dropout voltage of only 340mV).
Regarding your question about the ouput capacitor:
On page 7 of the datasheet a 2.2µF capacitor is suggested for most applications, but the 10µF capacitor will work just fine.
