Need help to double check LM317 circuit
floxia
Joined Mar 7, 2023
22
Hi there!
I have made the following schematic based on the datasheet from ST attached below.
Everything seems pretty straight forwards expect for the wiper of the pot R2, as it is unclear to me where it needs to be connected.
Is the schematic below correct?
Also in regards to the capacitors, C3 can be electrolytic, what about C1 and C2 can they be ceramic and electrolytic respectively given that C1 is non polarised while C2 is?
If it can help Vin will be 15V and Vout 7V, to power a circuit that draws 100mA.
Thanks!
Datasheet:
sarahMCML
Joined May 11, 2019
707
You need to connect the wiper of R2 to the top terminal of the pot, so that the pot just becomes a variable resistor. That's how the symbol shows it in the datasheet!
floxia
Joined Mar 7, 2023
22
Hi flox,
Wire the pot so that when fully clockwise it will be the maximum resistance [ max Vout]
C1 is ceramic and C2 is electrolytic.
The higher values are usually electrolytic,
E
Like so?
38,945
The reason is, that connection makes the output voltage linear with pot rotation, whereas the connection shown in the first post makes it non-linear.
See the difference below in the sim for the two configurations showing output voltage versus pot rotation .
floxia
Joined Mar 7, 2023
22
This may help.
E
Thank you guys for showing me the connections and simulations of the circuit, extremely helpful and appreciated!
Ian0
Joined Aug 7, 2020
13,315
That's not quite how he had it. The wiper went to R2 and the track end to ADJ.
It would have still been mainly linear, but the pot resistance would have been in series with ADJ which would have produced an error due to the 50uA ADJ current.
38,945
Correct.
I misread his first schematic.
