16 Volts
resistance is about 1,3 Ohm.
160 turns on plastic inner bobbin @ 0.2mm copper wire.
External case - some kind of soft metal. Not really hard. Easy to mill.
Small solenoid 11-13mm diameter -
factory solenoid is labeled EJ10014
The was it is setup it is a momentary push. Its a replacement part for an electronic trigger on a Olympic air pistol.
Any help find something that would work in its place or the exact product would be greatly appreciated.
16vDC
16vDC
