Need help selecting replacement opto coupler for variable PWM power supply.
Pauly F
Joined Nov 5, 2011
2
Hello all,
I am repairing a medical device which includes a PWM variable power supply which drives an LED. I have tested all but 2 components and the most likely culprit for the flickering LED is an opto-coupler which is available only in China.
Can anyone recommend a replacement for the component I need? It is labelled: JC817.
Here is a link to the datasheet: http://www.datasheet4u.com/download.php?id=730540
Thanks for your valuable expertise!
Paul
EM Fields
Joined Jun 8, 2016
578
Hello all,
Check out Sharp's PC817 series at: http://www.sharp-world.com/products/device-china/lineup/data/pdf/datasheet/pc817xnnsz_e.pdf
Paul
