Need help selecting a power supply for a grid-style hotwire foam cutter
Hotwirefoam
Joined Jul 12, 2016
8
Greetings,
I am building a hotwire cutter that uses a grid of wires instead of a single wire to cut foam. The grid is approximately 12" wide and 48" long and will be constructed of 18g or 19g stainless steel wire. The grid will be divided into 1" squares. I know that a single wire foam cutter can be powered by a 12v power supply, but I am having trouble calculating the amount of power I will need to heat this grid to a temperature suitable for melting polystyrene. Any help will be greatly appreciated. Thanks!
EM Fields
Joined Jun 8, 2016
583
Greetings,
http://hotwirefoamcutterinfo.com/_NiChromeData.html
BR-549
Joined Sep 22, 2013
4,928
+1 on that one. Great question. How does current flow thru chicken wire. This is gonna be good.
Do you have a schematic for the present system?
28,686
I have built a single wire foam cutter but in your case I would look at having the X & Y axis operate separate and independently operate one axis then the other, this way all the elements will be in parallel at any one time.
Hotwirefoam
Joined Jul 12, 2016
8
I thought about operating the x and y axis separately, but for my particular application having the whole grid heat up at once will be a huge time saver. After reading the link EM Fields posted, I am still unsure of how to calculate the requirements for the power supply I will need. The link provided was specifically for nichrome wire. I will be using stainless steel 18g, 19, or 20g at the absolute thinnest. If I assume that stainless steel is comparable to nichrome when it comes to resistance, will I be calculating my psu requirements on the total linear inches of the grid? If so, I am looking at a very large number of linear inches. If my calculation for linear inches is correct, I will need to raise the temperature of 1,261 linear inches of stainless wire to a degree that will melt foam. I don't think I will need it to be 600 Fahrenheit. I just need to make it hot enough to melt the pattern of the grid onto the top surface of the foam.
And thanks for the fast replies.
BR-549
Joined Sep 22, 2013
4,928
I would use separate nichr wires for both axis. I would separate the axis, a little more than the stretch of the wire.
Increase vertical stroke a little to make up for it, if needed.
jpanhalt
Joined Jan 18, 2008
11,087
If you look up the solution to this nerd sniping puzzle, it may shed some light on that question:
Source: https://xkcd.com/356/
I believe it is a fairly standard problem and well-known solution. The fact that your grid is not quite infinite doesn't mean the principle won't apply.
John
28,686
You could either do it by creating the grid and measure the resistance, it won't get that hot to melt foam so the cold resistance will be close, or you could set up a supply and carry out an empirical test using an automotive battery etc.
jpanhalt
Joined Jan 18, 2008
11,087
More seriously and based on my somewhat limited experience wire-cutting foam, I would not use a grid. That is, the horizontal and vertical wires would not be in the same plane.
In one plane, I would have the horizontal wires -- probably wired in parallel with an independent current control for each wire, if necessary. A small value balancing trimming resistor in series with each wire might work. In a second plane, I would have the vertical wires. I would separate the planes by more than the sag of the horizontal wires -- as a start, maybe 2 to 3 X the sag or 2", whichever is greater.
John
11,043
The original question is lacking some details, but IF the goal is to have a single voltage source with only two connections to the wire grid (+ and -, in and out, whatever), this will not work. There is nowhere you can connect the source of current that will assure equal current in all wire segments.
ian field
Joined Oct 27, 2012
6,536
Greetings,
It may have been EPE magazine that published a switchmode driver for this purpose a year or so ago.
It was a variable regulator AFAICR.
BR-549
Joined Sep 22, 2013
4,928
post #6 has one dc power supply, and is continuously heated. And one stroke operation.
I thought the app was for cutting. Are there any other conditions? You just want to burn a surface design, is that right?
Hotwirefoam
Joined Jul 12, 2016
8
Indeed this project is more for burning the design into foam rather than cutting it. I would prefer to use a large power supply wired in series. The material I will be using will be stainless steel chicken wire if possible.
Hotwirefoam
Joined Jul 12, 2016
8
If I did wire a power supply in series to this 12" X 48" wire grid, what ballpark am I looking at as far as power supply units go? I don't think using a power supply for each leg of this 12" X 48" grid will be feasible.
EM Fields
Joined Jun 8, 2016
583
The x axis doesn't touch the y axis.[/QUOTE]
I don't think that's true.
How would you solve the OP's problem from your point of view?
28,686
I would be inclined to make up a simpler smaller scale version to see if it is viable to get even conduction heating from a grid that will give you satisfactory results, if this is the method you want to pursue,
BR-549
Joined Sep 22, 2013
4,928
EM Fields, I was referring to my solution, but I thought he was cutting, not burning a design on surface.
Edit: "I am building a hotwire cutter that uses a grid of wires instead of a single wire to cut foam."
