Hi, I have the same problem, the board is new, the NTC controller is similar to yours but nothing is controlled, same symptoms as ypurs. Did you get any answer or resolution?Can anybody help me? I still could not find solution for the temp control.
The above mentioned KST011 with 7K (±4K tolerance) switching temperature seams huge temp fluctuation for my mycology needs.
If there is another option, I'm opened for it.
I re-read this Portuguese article. That board seems similar like mine and I'm happy to follow it but I have questions.
1. What type of NTC do I need for the NTC1 connector? Which should measure the outer temp.
2. Will work if I rebuild the "Internal panel, with potentiometer" according to the provided schematic? Which connect to NTC2 (three pin connector)
Moderator edit: New thread created from this.
