Need help repairing Allen & Heath Xone:DB4 mixer (2)
gm03
Joined Mar 7, 2023
14
Hi everybody, I have a problem with my Xone DB4 too
On the channel 2 & 3 the input selector is not able to switch to all input.
Exemple : I move from 2 to 3 to 4 ... 3 do not activate LED is off ans sound also.
If I power on the mixer with selector on 3 it works, but if I move the selector .. same issue.
Exactly the same on channel 2 with the 4 input.
Thks !!!!
Moderator edit: New thread created from this.
35,321
Bonjour!
If you set the selector switches before turning on power does the mixer work correctly after turning on?
DibElias
Joined Feb 28, 2023
129
Is this a matter of burnt LED light on the selector matrix?
Or can you still meter audio on your 3rd channel when selected in the matrix (regardless of led on or not)?
gm03
Joined Mar 7, 2023
14
No, the LED is OK .. The LED and the Audio does not work together...
If I power on the DB4 with selector on 3 .. the LED and the sound is OK ...
35,321
Suppose you power ON with the INPUT SELECT on 3, does everything work?
Now with power still ON, does everything work when you select 4?
gm03
Joined Mar 7, 2023
14
Yes when I select 4 it works .. but I cannot come back to input 3 .. I must power off .. select 3 .. and power on
gm03
Joined Mar 7, 2023
14
I have notice something, when I power on the DB4 on Track 2 & 3 .. the LED 4 & 3 flash 1/2s : the faulty input ... stange
