Need help on debugging/testing this ADC
goutham1995
Joined Feb 18, 2018
104
I have an ADC - https://datasheets.maximintegrated.com/en/ds/MAX11212.pdf which I want to debug. The SCLK and DOUT are connected to two GPIO's of my microcontroller STM32L496RGT6. Can anyone please explain the timing diagram or steps I should follow to retrieve the digital data from the ADC? I am confused about what I should do, since I am used to using readymade SPI functions which performs the timing for me.
ericgibbs
Joined Jan 29, 2010
21,572
hi 1995,
Have you studied the timing digram on page #10 of the datasheet.?
You send out 24 clock pulses and Read the data during the high of the clock pulses.
E
danadak
Joined Mar 10, 2018
4,057
Normally vendor has a demo board and code example for evaluating
a part like this. You might be able to download project code and do a port
to your part. Code port should be fairly simple for this.
Regards, Dana.
