Need help in this conversion please
S850
Joined Jul 1, 2015
1
I have the following information
three phase fault : I = 6060.08 <-175.6
Single phase fault: I = 4618.63 <170.7
How do I convert this to get the rectangular form, (R + jX) ??
MrAl
Joined Jun 17, 2014
13,783
You could use the relations:
A=sqrt(R^2+I^2)
Ph=atan2(I,R)
to find R and I, which are the real and imaginary parts.
A is the amplitude of the sine, Ph is the phase.
So for:
100*sin(wt+0.2)
the amplitude A=100 and the phase Ph=0.2 in radians.
shteii01
Joined Feb 19, 2010
4,644
The best way to do it is to draw the right triangle.
You are given the hypotenuse of the right triangle, and the angle from the origin.
You have right triangle.
Hypotenuse is 4618.63
The angle inside the triangle is 180°-170.7°=9.3°
You need to find the R part and X part.
cos(9.3°)=R part/hypotenuse
cos(9.3°)=R part/4618.63
R part= 4618.63*cos(9.3°)
This gives you the magnitude of R part.
Since R part lies on the left of the origin, it will have negative sign.
You should be able to figure out the X part on your own.
